pc blijft nog altijd hangen
HKU\S-1-5-21-1078081533-73586283-1801674531-1003\Console 6/08/2011 19:59 0 bytes Security mismatch.
HKU\S-1-5-21-1078081533-73586283-1801674531-1003\Console\Afsluiten 6/08/2011 19:59 0 bytes Security mismatch.
HKU\S-1-5-21-1078081533-73586283-1801674531-1003\Console\MSN update 6/08/2011 19:59 0 bytes Security mismatch.
HKU\S-1-5-21-1078081533-73586283-1801674531-1003\Console\shutdown.exe 6/08/2011 19:59 0 bytes Security mismatch.
HKLM\SECURITY\Policy\Secrets\SAC* 28/09/2009 13:57 0 bytes Key name contains embedded nulls (*)
HKLM\SECURITY\Policy\Secrets\SAI* 28/09/2009 13:57 0 bytes Key name contains embedded nulls (*)
HKLM\SOFTWARE\Swearware\backup\winsock2 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\NameSpace_Catalog5 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\000000000001 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\000000000002 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\000000000003 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000001 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000002 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000003 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000004 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000005 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000006 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000007 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000008 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000009 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000010 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000011 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000012 9/02/2011 19:33 0 bytes Security mismatch.
HKLM\SOFTWARE\Swearware\backup\winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\000000000013 9/02/2011 19:33 0 bytes Security mismatch.
C:\Documents and Settings\Rudi\Local Settings\Application Data\Mozilla\Firefox\Profiles\r5rne8rk.default\Cache\0\84 7/08/2011 20:30 0 bytes Hidden from Windows API.
C:\Documents and Settings\Rudi\Local Settings\Application Data\Mozilla\Firefox\Profiles\r5rne8rk.default\Cache\0\84\F3D9Dd01 7/08/2011 20:30 108.75 KB Hidden from Windows API.
C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll 19/11/2010 21:17 252.00 KB Visible in Windows API, but not in MFT or directory index.
C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll 19/11/2010 21:17 111.00 KB Visible in Windows API, but not in MFT or directory index.
C:\WINDOWS\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a\IEExecRemote.dll 19/11/2010 21:17 8.00 KB Visible in Windows API, but not in MFT or directory index.
en ikke maar zoeken , is da natuurlijk een verborgen file :mad:
Op het filmpje valt weinig te zien hoor. Het lijkt eerder hardware gerelateerd. Tussen haakjes een PC met de kast open is zeker niet beter gekoeld dan met de kast dicht (aangenomen dat de ventilatie niet vol stof zit ofzo). De voeding zou ook een probleem kunnen zijn?
Ik zou de temperatuur eens in de gaten houden wanneer het probleem optreedt.
Kan je het volgende eens doen ?
Dit (KLIK) filmpje laat zien hoe je een Speccy-logje moet plakken in je antwoord.
